Anyone here used BG44k..?
I came across this thread, and it sounds pretty good to me. i might give it a try since i have over 100k miles. http://www.bobistheoilguy.com/forums/ubbth...&Number=1355086
the bg-44k is a very good product. it is to clean youe entire fuel system, it is put inside the gas tank. cleans out fuel lines, gummed up injectors. etc. i have known may people that have tried this product and it definatly make a difference. made the car run a little smoother. you will only notice the difference mostly if your engine's fuel system is over due for a tune up. we use this at my work (honda windward in hawaii) and they swear by this product. and have not heard anything bad about it so far. it is more of a maintanence thing. done periodically to keep your fuel system clean. especially if you used bad gas in the past. many shops use bg products.
Former Sponsor
Hmm maybe could benefit from this. I've never used any sort of cleaner before? Available at any local stores usually?
Or similar one that is just as good that is?
Former Sponsor
Originally Posted by TookayS2K,Oct 17 2010, 12:41 PM
Seafoam will do the same thing if you can't find it.
Always run the tecron product. My late friend used to work for Chevron and sold me on the tecron chemical. It might be one of the most complex cleaner on the market.
BG44K is good but I'm under the impression Tecron is better.
we use it at my shop and i have been using it for years and swear by it !
Only fuel system cleaner I would consider though I rarely almost never use one. Not the easiest stuff to find either, at least not over the counter.
