Any using a Blaupunkt 'Class T' amp in their S2000?
With these amps being so small and not producing much heat, I thought they might be an excellent choice for a S2000. I'm just wondering if everything I read about these amps is really true.
[QUOTE]from http://www.blaupunktusa.com/amps/amps_index.html
Today's amplifier market is overloaded with products that all look and
STL, did they give any other specs for the amp. Thing to look for :
Power @ 4 ohm load
Power @ 2 ohm load
Distortion
S/N ratio
Slew Rate
Dampening factor
These 6 items will give you a really good look at what the amp is capable of.
Power @ 4 ohm load
Power @ 2 ohm load
Distortion
S/N ratio
Slew Rate
Dampening factor
I have asked this before
the best place to look os crutchfield for all the specs
they are good amps
their 4 channel is 100 X 4 RMS at 4ohms
about 499 at crutchfield but you can always get it somewhere else.
I beleive they are the ideal choice for a car with a limited space.
they are definitely on my list.
GERMAN TECHNOLOGY, can't mess with it
they are good amps
Originally posted by ZAMBONO
the best place to look is crutchfield for all the specs
