any MY06+ change their seats?
has anyone found a way around the air bag sensor in the seats of MY06+? i wanna change my seats, but if it compromises the whole SRS in my car then it won't be worth the trouble. anybody find a solution?
You need to use the stock seat rails from the 2006 seats to keep the SRS airbag sensors working and keep the light off your dashboard.
I swapped seats with a guy who had a 2006 (I have his 2006 seats in my car and he put AP1 seats in his car) and we had to swap the seat rails . . . both to make them fit right and to get the sensors to work.
Feel free to PM me or look for my thread I made on it for more info.
I assume you want to put aftermarket bucket seats correct? You can change the drivers seat no problem. you just have to remove a sensor from the factory rail and place it on the floor under the driver's seat. The passenger seat is another story though. That cannot be changed without getting a SRS light. For the 06+ they added a weight sensor that is tied into the factory rails. No way around this. Also if you decide you dont care and change it anyway then your aftermarket rail will have to be modified to fit in the car. There is a hump that they added in the floor of the 06+. Hope this helps.
Originally Posted by timaneo,Jan 18 2007, 03:56 PM
Theres an srs sensor in the seat? Whats it for?
thanks for all the help guys
[QUOTE=Jsmply,Jan 18 2007, 03:16 PM]You need to use the stock seat rails from the 2006 seats to keep the SRS airbag sensors working and keep the light off your dashboard.
