Another shock other then the konis?
Is there an alternative to the koni yellows? I've had them before and while a good set, im looking for something different. Any help? I have espelir springs to compliment them.
Also if there isn't a real alternative to the konis, can anyone recommend a good place to buy them, my local shop went under.
You can get 1 way adjustable JRZ's for around $2k. After that they get expensive. Or you could get some low end coilovers for $1-$2k and other than ride adjustment it is debatable whether or not they are better than stock. You can pm dut for a guy supplying koni's for a real good price.
the best price for Konis is around $600. I had them on my GS-R and loved them. I thought about getting them on my S but I'm wondering if they will be an improvement.
They are a quality shock. I'm told they will last longer on a track if you are into that. And they match up well with stiffer than stock springs. Since you can get ground control adjustable springs in any spring rate you want you can have a custom adjustable coilover set for around $1k
Whoabitchin
01-21-2012 07:57 AM
SSSS2222KKKK
06-03-2008 12:58 AM
