Another rear speaker believer!!!
If you are considering a new sound system for your S2000, I would urge you to first install the Polk 602 (or equivilent) in the doors and Lucid's rear panel speakers. This combination makes the stock sound system sound like an expensive name brand upgrade for just a few hundred dollars.
Thanks Lucid. The rear speaker setup was a cinch to install and sounds better than I hoped!
Lucid is the guy that markets pre-cut rear panels that accept small 4" speakers. Even though these panels are located behind the seats, people report that they add a lot to the sound quality in our car. Here's a link to his FAQ page:
http://members.aol.com/lucids2000/faq.html
I need some input on how to achieve sonic nirvana with Lucid's upgrade in my application. I have already upgraded to 6 1/2" Infinity coaxials in the doors powered by a small 2-channel amp. The amp is powered by the stock head unit through a low-level converter.
How can I install the 2 additional speakers? Do I connect them directly to the unused rear speaker outputs of the head unit? If so, will I be able to balance the output so that I can even hear the rear speakers? I really don't want to add another amp. TIA
