Alignment specs?
Alignment specs?
What are the stock alignment specs for an s2000? And does it matter if my car is lowered with koni yellows/espelir springs? It is almost a 2" drop... I am going in for an alignment and I want to be able to actually give him the specs instead of chancing them putting in the wrong specs.
I don't know about specs when lowered.
(cant read the specs posted, so maybe the answer is on there?)
Btw.. are they able to manually enter specs in the computer?
Usually they search for the make/model/etc and the right specs are there.
There's a copy hosted for the public somewhere on s2ki. It took me a while to find it last night while on a computer inside the dealership service garage.
Basically it has minimum and optimal settings, I think optimal is this:
Front-
-1 degree camber each side
6.45 caster each side (although we were only able to get 5.5/5.7 with the camber at -1.3 each side)
0 toe
Rear-
.20 toe in each side (.40 total)
-2.0 camber each side.
All that being said, i'm not sure what specs you'll want to use with a modified suspension. The bulletin specifically stated that it was only for stock 99-03 cars.
EDIT: Here's what you need Mark
https://www.s2ki.com/forums/index.php?act=m...image&img=12060
Front-
0 toe
Rear-
secretdonkey
11-05-2005 11:39 AM
