Alignment problem following transmission TSB
Old 11-10-2000 | 12:42 PM
honda_s2k's Avatar
Who has had an alignment problem following the transmission repair? Even before seeing it posted up in the Planning Room by Power6Spd, it seemed to me that my car was slightly out of alignment. Following the work that was done, it now seems to have a tendency to drift to the right. I guess I'll be calling my Honda dealer tomorrow about this.
Old 11-10-2000 | 01:32 PM
SilverSurfer's Avatar
I had the same problem with my car after the 1-2 grind fix was done. Unfortunately it is not in the procedures to do an alignment after the repair is done. My dealer has added that procedure to his list when they do the 1-2 grind. My alignment was way off...I had to turn the wheel about 15-20 degrees to go straight.
Old 11-10-2000 | 02:27 PM
Molly W's Avatar
I actually had not noticed a problem with the alignment, but when they did teh test drive afterward they noticed an alignment problem and fixed it before I picked the car up. Interesting that it is happening to so many.Mine was pulling to the right too according to the mechanic.
Old 11-10-2000 | 02:44 PM
Greece_S2000's Avatar
That's weird. I had my tranny excanged for the improved one (the whole box) and the whole job was carried out at my presence. They didn't even touched a single suspension part, so for me no alignment was needed. What was the suspension part tha was getting in their way and they had to remove?
Additionally you might want to know that over here they are recalling the S2000 to exchange the tranny with a new one which has not only upgrated parts on the 2nd gear synchros but also a beefier oil pump to maintain appropriate oil flow at extended high speed runs. I did the swap 2 months ago and the new tranny shows no hint of grinding gears no matter what.
Old 11-10-2000 | 03:28 PM
RHES2K's Avatar
I also had the alignment problem after the 1-2 fix. They have to disconnect the steering to drop the tranny. Car's still in the shop to fix all the things they screwed up. Hope to get it back Saturday morning so I can meet up with Mingster etc. The shop foreman said they won't go home until the car is done. (Ya right!)
Steve
Old 11-10-2000 | 04:19 PM
honda_s2k's Avatar
[QUOTE]Originally posted by Greece_S2000:
[B]That's weird. I had my tranny excanged for the improved one (the whole box) and the whole job was carried out at my presence. They didn't even touched a single suspension part, so for me no alignment was needed. What was the suspension part tha was getting in their way and they had to remove?
Old 11-11-2000 | 04:25 AM
Luis's Avatar
It's the steering wheel that is out of alignment not the suspension.
They have to disconnect the steering shaft to get to the transmission, but they forget to mark it, and so when they put it back together the steering wheel is off.
Lousy job. Has happened to me.
Old 11-11-2000 | 04:30 AM
honda_s2k's Avatar
Luis,
The steering wheel in my car is perfectly aligned. The car just doesn't track as straight as it used to.
Old 11-11-2000 | 05:59 AM
Luis's Avatar
Luis,
That's the problem. When the steering wheel is centered the front wheels are not! They need to recenter the steering wheel.
Old 11-11-2000 | 09:35 AM
Pinky's Avatar
Shelly should add that to the 1-2 grind fix page! Shelly you listening!?
Quick Reply: Alignment problem following transmission TSB
