The ALEX engine torque damper
The Alex Engine Torque Damper reduces engine movement under on/off throttle conditions such as gear shifts. Consequently, engine power is more directly transferred the wheels and wheel hop is reduced. The reduction of wheel hop is particularly noticeable on the RSX's first to second gear shift. The torque damper is made from CNC aluminum and chromoly steel. The damper itself consists of ABS plastic enclosed in a CNC aluminum sleeve. The plastic is compressed upon when the engine moves under load. The torque damper is compatible with engine mount upgrades and is highly recommended for high horsepower cars.
*EP3 application requires drilling of holes
HONDA
S2000 00+ AP1 Requires Modification $355cdn / $268usd
**info & pic copied from Aj-racing.com**
So...does anybody have this? how is it compared to J's Racing engine damper? It sounds like the J's use nylon for flexing and these use plastic...is that the only major difference? i like the "tein-looking" green better than orange...
Alex or J's?
I dont have one, but I will vouch they make a BIIIIIIIIG difference. HUGE difference. I installed one in my friend;s RSX and the difference is big. The motor vibrations are greater while standing still, but MUCH less when you are moving.
Keep in mind the differences you felt on an RSX may have to do with it being FWD. The device pictured sure looks like it's based on a steering damper you'd find on a sportbike..
Former Sponsor
Originally Posted by ideugene,Jan 2 2005, 08:37 PM
I was considering this... but was turned off by stories of the j's not fitting right. I wonder how these fit.
picky...
