After 4+ years, should I change all the fluids?
Old 03-18-2004, 05:00 AM
scottrnelson's Avatar
Default After 4+ years, should I change all the fluids?
It's about time for my annual oil change. My 2000 S2000 has less than 17,000 miles on it (I've only had one year when I put more than 5000 miles on it in a year). I generally go to the Honda dealer to get the oil changed every year in the spring. Should I have any of the other fluids changed, like transmission oil, differential, coolant and so on?
Before I get flamed for not driving the car enough, it's not a daily driver, I only have a two mile "commute", I spend weekends riding my Ducati, and I really need to take the car out more. I'm hoping to put a few thousand miles on it in May. Still, I want to keep the car in perfect condition and plan to own it for a few more decades. Any informed opinions on this matter would be appreciated.
Old 03-18-2004, 05:14 AM
HOTRODS2000's Avatar
I would absolutely change all the fluids and don't forget the hydraulic clutch fluid. It is easy to overlook.
Old 03-18-2004, 05:15 AM
Squeezer's Avatar
yes, i'd flush and replace coolant, tranny fluid, diff fluid, brake fluid, and master/slave cyl fluid
Old 03-18-2004, 05:31 AM
Smokee's Avatar
Just curious, why replace coolant? It's recommended interval is something like 10 years.
Old 03-18-2004, 05:40 AM
ruexp67's Avatar
I wouldn't do coolant, but I would do Diff, Brake and Tranny. In fact I would have done the Diff about 7-10k mi ago.
I see you are in CA so I don't think this is a concern, but if you store the car for a long period the common wisdom is to change the oil before storage. So if you are storing it over the winter and taking the car out in the spring and THEN having the oil changed you might want to change your interval to the fall.
Old 03-18-2004, 05:47 AM
s2kpdx01's Avatar
[QUOTE]Originally posted by Smokee
Old 03-18-2004, 05:51 AM
ruexp67's Avatar
[QUOTE]Originally posted by s2kpdx01
Old 03-18-2004, 06:11 AM
payyourtoll's Avatar
I agree, changing your coolant every year IF your car is a street car is not necessary. Making sure the level is correct IS however necessary. Mine was low the other day I checked it
Old 03-18-2004, 07:18 AM
Squeezer's Avatar
Old 03-18-2004, 07:35 AM
Thanks for the input so far. I guess I had better start saving my money so that I can afford the next service.
Quick Reply: After 4+ years, should I change all the fluids?
