AEM V2 CAI pros/cons
Banned
I just got the AEM V2 CAI but havent installed it yet. Is it true I may need a dremel to install? Plus, I hear good and bad things about using this CAI. Is it smart to use this V2 CAI or not?
Pros:
- makes for a really cool sound
- is a "performance" intake as well as a cold air intake
- frees up a lot of space in the engine bay so you can do oil changes much more easily.
Cons:
- you must build yourself an "umbrella" to prevent water from dripping onto the filter (sucks in water if you don't); also plug the hole in the water channel under the edge of the hood.
- frees up a lot of space in the engine bay and makes it look almost "naked"
- requires cutting of plastic in 2 places
- access to get at filter for cleaning is difficult
Cons:
Originally Posted by Graphtuner,Jun 12 2006, 08:15 AM
use the search... plenty of information around about this.
I have the V2, I'm happy with it but don't expect miracles.
Yes you have to cut some plastic to make room for the tubes to pass...
Originally Posted by Ztopgun28,Jun 12 2006, 11:19 AM
how do I make the umbrella thing? With what material and where does it go exactly?
Or you can buy one:
http://www.cardomain.com/item/INJHS5000P
