AEM CAI, a quick question for all who installed it.
Last night I installed a red AEM cold air in my S. First let me say the hours on my back trimming the splash guards was worth it. However, when I took it out in the early hours for its shake down run I heard a minor rattling at idle. Has anyone experienced this? Is there a reason and remedy for it? I think it might me the down pipe touching a metal pipe somewhere below, but I can't be sure.
Any input would be greatly appreciated.
Also: what STB will clear the AEM CAI? I had/have a Neuspeed STB but it does not clear the intake pipe.
On the AEM CAI the downpipe has a bolt with a rubber bushing on it. Make sure that bolt is fastened securely as the rubber bushing absorbs any vibrations. Make sure that nothing else touches the downpipe, for example, make sure the plastic splash guard is not touching the downpipe. Cut the splash guard a little bit larger than the diameter of the downpipe otherwise when the car is driven, the wind will make the splash guard vibrate against the downpipe. Also if you did install the bypass valve, make sure that it does not vibrate against the radiator fan housing. Last but not least is to make sure that all other parts that were fastened to the factory intake are properly fastened to the body of the car.
Does the AEM bypass filter fit in-line with the CAI or do you have to make a special cut? How long did it take you to make the cuts (and do the entire install) and did you have to have it up on jacks? I am oredering my AEM CIA today, enjoy!
Thanks,
Nix
Thanks,
Nix
I just picked one of these up as well and will hopefully be installing soon - at least as soon as it gets here. Thanks for the tips. BTW: Where did you get yours and how much $$?
[QUOTE]Originally posted by RU2KREDY
[B]I just picked one of these up as well and will hopefully be installing soon - at least as soon as it gets here.
