added 1 qt. at 2800 Mi. is this in the normal range ?
Old 07-17-2001, 07:12 AM
yidal8's Avatar
Default added 1 qt. at 2800 Mi. is this in the normal range ?
I know there is a ton of threads on innitial oil consumption . Just doublechecking .
Also V-TEC feels weaker after I added the 10w-30 oil . This is strange and complete opposite to what you would expect .(maybe just coincedence and is because of bad gas or something ? )
Old 07-17-2001, 07:19 AM
joe_s2k's Avatar
I went through 2-3 quarts during my first 3,000 miles. Don't be worried. Just keep checking your oil at every fillup and you'll be fine. I used to check my oil every morning before I drove to work during my first 5k miles. The consumption should taper off, but I still use oil at 29k. Very normal when VTECing alot.
Don't forget to use non-synthetic 10w-30 when topping it off.
Old 07-17-2001, 07:52 AM
Palmateer's Avatar
Good advice, joe_s2k
Old 07-18-2001, 05:11 AM
dlq04's Avatar
Received 5,746 Likes on 3,385 Posts
Sounds normal. I used two quarts in first 3,600 miles - when I did the first oil change. Runs sweet; not to worry, if you check it with every gas fill up.
Old 07-18-2001, 05:33 AM
Former Sponsor
Rick Hesel's Avatar
I went through about 2 quarts in the first 3,500 and nothing in the next 3,000.
Old 07-18-2001, 11:57 AM
y2ks2k's Avatar
My 2000 Did not burn oil, I have put 1 quart in after 2000 in my 2001 and I think I need another at 3K now.
Old 07-18-2001, 01:36 PM
Utah S2K's Avatar
Yes that is a normal amount.......
Old 07-18-2001, 02:49 PM
turn key terror's Avatar
Checked oil at 2200, needed 3 quarts.
Old 07-18-2001, 03:00 PM
JoeyO S2K's Avatar
I'm at 3300 miles and almost at the end of my third quart. It's normal.
Old 07-18-2001, 03:04 PM
wanabe's Avatar
4 quarts in 4,000 miles...
and whole lots of VTEC goin on!
Quick Reply: added 1 qt. at 2800 Mi. is this in the normal range ?
