Accidentally downshifted to 2nd at 70MPH..
Old 10-07-2010, 12:50 PM
  #31
RedCelica's Avatar
Originally Posted by MBHs2k,Oct 7 2010, 02:17 PM
I love how everyone is trying to give better driving techniques now haha
It could have happened to anybody, even the most experienced driver. If you pulled it out of gear real fast before the motor had time to sit at redline than i think that you may be ok. If your worried about it just go get your heads checked. It should be rather cheap and easy. Good Luck
heads???
Old 10-07-2010, 01:33 PM
  #32
dammitjim's Avatar
Check your head
Old 10-07-2010, 01:48 PM
  #33
importrule's Avatar
from personal experience.. more than likely, you're ok.
like what most said, comp and leak down test. that way you'll have an idea of what's going on with it...
if you feel like there's some powerloss in the higher rpm band.... valve adjustment will be able to retrieve some of that power back... this ALSO is from personal experience... unfortunately.
Old 10-07-2010, 02:40 PM
  #34
whiteflash's Avatar
A) Don't feel bad... mis-shifts happen... even to the best of us.
B) As suggested you must definitely wanna run some diagnostics [Leakdown, compression]
C) Your mechanical rev's shot up to +/- 10K Rpm's, that's high on an AP2. If this is the cars first mis-shift, it's PROBABLY fine, but you don't know the condition of it before hand.
Old 10-07-2010, 04:56 PM
  #35
Fredster's Avatar
Originally Posted by hondafrvr,Oct 7 2010, 08:07 AM
^ or you could go from 6th to 3rd. At 70mph thats VTEC and "passing zone"
And going from 6th to 3rd you cant misshift because 1st is locked out anyway right?
WRONG!! Down shifting from 6th to 3rd is another dangerous shift if you're a dumb driver. My friend did this and shifted to 1st instead at 70mph! OUCH! Needless to say that down the road a retainer failed and it dropped a valve (AP1).
Old 10-07-2010, 05:01 PM
  #36
whiteflash's Avatar
Down the road? 70mph first gear shift? I'm pretty sure that'd take the block with it... I don't even know what kind of hammer fisted gear changes your friend is making to engage first gear without ever noticing "this isn't right".
Old 10-07-2010, 05:18 PM
  #37
G
G's Avatar
You must have slammed it into 2nd since at that speed it should not slip nicely in. And you were probably pissed so you made the mad shift.
I was told by an Acura Tech once to NEVER skip gears when shifting up or down. Always hit each. It will be much nicer on your syncros and you will not have this issue again.
Old 10-07-2010, 05:24 PM
  #38
sean2k's Avatar
i thought if you rev matched you can skip gear downshift with no detriment
Old 10-07-2010, 05:31 PM
  #39
Fredster's Avatar
take my word, how he managed to do so? i don't know, he must of really yanked that gear in. i was with him at the time, and i could only say that he probably did manage to engage the clutch quite rapidly reducing the damage or enabling the rpm's to go any higher amazingly no CEL or anything. his car kept running fine up until he misshifted again from 4th to 2nd, that time around he wasn't so lucky.
Old 10-07-2010, 07:13 PM
  #40
Robert O's Avatar
How do you misshift from 4th to 2nd ???
Quick Reply: Accidentally downshifted to 2nd at 70MPH..
