AC Question
AC Question
Another Hot & Very Humid day in Louisville......Had the AC on Full Blast for about an hour with the top and windows down. Once arriving at my destination my passanger noticed a wet spot on the right side floor mat directly under the evaporator. I checked the hose it looked good and there was water all over the driveway so I know some water is draining through the hose. Anybody else experience this or do I have a major problem?
Originally posted by Hondafan
Once arriving at my destination my passanger noticed a wet spot on the right side floor mat directly under the evaporator. Anybody else experience this or do I have a major problem?
I have had this problem on the last two cars that I had. One had a plugged drain tube (yours sounds OK) and the other had a bad gasket around the evaporator (this may be your problem). At any rate, this is no big deal. Just don't use the AC until it's fixed. I don't use mine any way.
Good luck with the repair,
Bob
Hondafan,
I signed on today for the sole purpose of seeing if anyone else experienced this problem. Today 95degrees+ HUMID, top down with a/c on, my wife as co-pilot, advises me water is dripping right in the middle of the passenger side mat. I'm calling my local dealer tomorrow. Haven't checked to see where it is coming from, but certainly this isn't normal. I'll post their response. Meanwhile, all passengers must wear rubber boots.
MIKE
MIKE
Originally posted by 2kturkey
Hmm, wet spot on the passenger carpet.
I thougt I'd tried evey position in the Kama sutra but what position do you call that?
There is a TSB on the passenger side AC leak -- the library on this site has it -- but as you are aware the search function is DEAD ---
I had the TSB done and it did reduce the leak on the passenger side -- but my wife informed me that it still leaks a bit on her feet ... but not as much as last summer.
Why isn't this a normal response to high humidity, topdown, AC on conditions?
Won't the evaporator continuously have condensation on it's surface in high humidity conditions? Unless I put the top up, mine will also drip onto the floormat.
I think this is more condensation than a leak. I live in one of the most humid populous cities in the world, and all of my cars have had at least one-drop leaks if you run the ac and put the windows down.
