ac comes on when in defrost mode. feature or glitch?
Old 04-06-2008, 12:54 AM
  #31
raisantos's Avatar
Originally Posted by oOweEe,Mar 15 2008, 02:57 AM
i believe contra's cheat is: up down up down left right left right b a b a.
been about 15 years. i wonder if thats right.
sorry guys but you are all wrong... almost there though
.... i'll never forget this... i dont know why... hehe
UP, UP, DOWN, DOWN, LEFT, RIGHT, LEFT, RIGHT, B, A, B, A, [Select,] start....
bam... 30 lives baby...
or in our car's case.... A/C off when defoging...
(has it been 15 years???)
raisantos is offline
Old 01-01-2009, 11:16 PM
  #32
savesday04's Avatar
awesome... worked good for me. A/C still comes on when switched to defrost but now i can just push the a/c button and it will turn off.
savesday04 is offline
Old 01-02-2009, 02:45 AM
  #33
Ks320's Avatar
Originally Posted by sebrings2k' date='Dec 15 2003, 02:32 AM
Its not a defect...just a function built into the car.
Running the AC de-humidifies the air that comes into the cabin, which helps the defrosting process.
Try this,
To deactivate automatic a/c feature on 2002 CR-V:
1) Turn vehicle off.
2) Turn fan knob off.
3) Turn temperature knob all the way to the left (blue area).
4) Turn vent knob to panel only setting (next to max a/c).
5) Hold down both air recirculation button and a/c button while starting car.
6) Continue holding for 7 seconds until air recirculation button stops flashing.
To reactivate automatic a/c feature on 2002 CR-V:
4) Turn vent knob all the way to the right (defrost position).
7) After the 7 seconds described in step 6, the recirculation button will start to flash. Continue to hold the button for another 7 seconds. After this, the a/c light will turn to green and it's finished!
Although this write up is based on a Honda CRV it also works for the S2000. I've done it twice so far. If you in any case dis-connect your battery terminal, you'll have to go through the process again.
Honestly ... I sometimes wonder how the heck people can figure these things out. I mean, that's like one of those up + down + A + B + B then wait for 2 seconds then hit L + R hacks that people figure out with Nintendo and Playstation games ...
This is why I love this board so much. There are things and info here that I would never be able to figure out in my lifetime ...
Anyways, it's a feature. I disabled mine as well, but actually never used it -- i.e. I never use those vents unless I turn the A/C on to defrost.
Ks320 is offline
Old 01-02-2009, 05:21 AM
  #34
ts80's Avatar
Those "codes" are designed from the factory. You can find them all out by looking into the appropriate documents (for example, a dealership service manual would contain a lot of them).
ts80 is offline
Old 01-04-2009, 07:14 AM
  #35
jeffbrig's Avatar
It's up, up, down, down, left, right, left, right, B, A, select, then start.
Amateurs....
jeffbrig is offline
Old 01-04-2009, 11:59 PM
  #36
Forcedbird's Avatar
I thought it's 99 lives.
Forcedbird is offline
Old 01-05-2009, 05:50 AM
  #37
21337R's Avatar
@ Contra code, man that brings back memories. That code actually worked on quite a few other Kanami games.
21337R is offline
Old 01-05-2009, 08:08 AM
  #38
Triple-H's Avatar
Originally Posted by tof' date='Apr 5 2008, 09:44 PM
AC still comes on when I rotate the knob to defrost but I can turn it off now.
Exactly! I think lots of people get confused by this '02 and '03 mod. The change does not mean the AC never comes on when you select defrost, it just means you now have the manual ability to turn the silly thing off. I have been doing this for years and years as I have to redo it every spring when I put the battery back in. Works great, fantastic mod!
Triple-H is offline
Old 01-05-2009, 10:14 AM
  #39
wuttheheezy's Avatar
Amateurs....
finally someone gets it right on the button!! thanks!
wuttheheezy is offline
Old 01-05-2009, 10:45 PM
  #40
crazysupratt's Avatar
did anyone get this to work on 06? i tried it but no luck.
crazysupratt is offline
Quick Reply: ac comes on when in defrost mode. feature or glitch?
