ac comes on when in defrost mode. feature or glitch?
there are two ways to defog your windsheild
1) Dehumidify the air inside the cabin
2) Heat up the windsheild.
When you use the a/c, #1 happens almost instantaneously.
When you don't use it, it takes a while for the car to warm up and generate heat thru the vents, hence taking longer.
02+ hondas all had this feature.
Here's another point, there have been 3 topics on this in the past week, all longer than 2 pages.
Did they not turn up in the search function?
even better than the search function,
http://forums.s2ki.com/forums/showthread.p...threadid=108435
definatly an untapped gold mind that people seem to overlook.
I used these instructions to gain control over whether the A/C was on or not while using my defroster very recently. They worked fine on my '03, with the exception that it was the green A/C light that blinked, not the orange Recirculate light (as described in the instructions). Anyone else have this same experience?
I recently found some rainX anti-fog in a black plastic bottle at Walmart. It's for interior glass and works good to stop inside fogging and steaming of the windshield. I think when the soft-top gets wet, it takes extra long to defrost the windshield but this helps.
Originally Posted by SASprof,Dec 14 2003, 11:16 PM
i pushed ac button, but ac wouldn't go off. ???
Originally Posted by sebrings2k,Dec 15 2003, 03:32 AM
Its not a defect...just a function built into the car.
Running the AC de-humidifies the air that comes into the cabin, which helps the defrosting process.
Try this,
To deactivate automatic a/c feature on 2002 CR-V:
1) Turn vehicle off.
2) Turn fan knob off.
3) Turn temperature knob all the way to the left (blue area).
4) Turn vent knob to panel only setting (next to max a/c).
5) Hold down both air recirculation button and a/c button while starting car.
6) Continue holding for 7 seconds until air recirculation button stops flashing.
To reactivate automatic a/c feature on 2002 CR-V:
4) Turn vent knob all the way to the right (defrost position).
7) After the 7 seconds described in step 6, the recirculation button will start to flash. Continue to hold the button for another 7 seconds. After this, the a/c light will turn to green and it's finished!
Although this write up is based on a Honda CRV it also works for the S2000. I've done it twice so far. If you in any case dis-connect your battery terminal, you'll have to go through the process again.
Try this,
The description seems really vague... not technically defined.
In step #4... which is the panel setting?
In step #5... do we really start the car?
Andre
