60,000 mile service
60,000 mile service
is it worth getting the 60,000 mile service done on the s2k?? the local honda dealership around here charges like $500 to do it, i looked online to see exactly what is done and most if it seems like pretty basic stuff like changing your oil, adding fuel injector cleaner and, putting in new tranny fluid and stuff like that.. doesnt seem over all to be worth paying $500 for... can anyone give me some insite as to wether or not its worth it??
heres the list of what they do
60,000 / 120,000 Mile Service
- Replace engine oil and filter
- Add BG MOA*
- Add BG 44K Fuel System Cleaner*
- Inspect front and rear brakes
Check pads and discs for wear (thickness) and damage
Check calipers for leaks and tightness of mount bolts
Check brake shoes for cracking, glazing, wear, and contamination
Check wheel cylinders for leaks
- Rotate tires. Follow the pattern shown in the Owner's Manual. Check tire inflation and condition. Inspect tie-rod ends; steering gear box, and boots
Check steering linkage for looseness
Check condition of rack boots
Check fluid lines for damage and leaks
- Inspect suspension components
Check bolts for tightness
Check ball joint boots for deterioration and damage
- Inspect driveshaft boots for cracks, and check boot bands for tightness
- Clean air cleaner element- Check parking brake adjustment
- Lubricate all locks and hinges with multipurpose grease or Honda White Lithium Grease
- Inspect brake hoses and lines. Check the master cylinder, proportioning control valve, and ABS modulator for damage and leakage
- Check all fluid levels, condition of fluids, condition of fluids, and check for leaks.
- Inspect cooling system hoses and connections
Check for damage, leaks, and deterioration
Check for proper fan operation
- Inspect cooling system. Check catalytic converter heat shield, exhaust pipe, and muffler for damage, leaks, and tightness
- Inspect fuel lines and connections. Check for leaks
- Check operation of all lights
- Inspect the underbody. Check frame and panels for damage. Check paint for scratches and stone chipping
- Replace air conditioning filter if the vehicle is driven in urban areas with a high concentration of soot. Replace air cleaner element.
- Replace Spark plugs (4-cylinder models)
- Inspect and adjust drivebelts
- Replace transmission fluid
- Add BG MOA*
I highly doubt your dealer will even perform all those minor checks. Sad but true. I think they'll probably just end up changing your fluids and filters.
mine was 460 but i'm not a mechanic guy. To me, I thought the price was too high but if anything was wrong I could have the dealer to blame. The car felt alot smoother afterwards and all the problems I had vanished. Shifting became much easier (especially after that horrible day) One thing though, they didn't fricking vacumm my interior! I hear getting oil changes you get vacumm'd.
they dont rotate your tires since the fronts and backs are different sizes and im pretty sure the tires are directionals.
i doubt they check half that stuff besides your brakes. then they tell you that you need new brake pads.
the spark plugs are good to 105k miles in the s2k according to the service manual, so they wont be changing those either.
its a waste of a few hundred bucks.
if you can, change your own oil, trans fluid, diff fluid, cabin and air filter and save about $400. all you really need is a jack and a few tools.
Most of these "CHECK" items would probably take them less than a couple of minutes. You could check these items yourself and probably better in 15-20 minutes.
Instruct them not to check anything(already done). Instruct them to change all fluids and filters.
Benefit of a doubt- A two hour job @ $100/hr plus parts $100est= $300 estimated.
Save $200.
Save $200.
The thing is, if you really have to ask, you probably not really that good mechanically or around cars.
just have the dealer do it for you, sure some of the item takes no time to check but it makes a difference between trained eyes vs average joe's
plus it's a GOOD investement anyway, esp when you selling the car, i would give more money knowing the previous guy didn't just give it a hug for good luck at 60k
ask nicely for them to check the condition of the retainer also
hughs2
12-01-2006 11:05 AM
BigTed
10-28-2003 09:58 AM
meloman
08-26-2002 05:28 PM
