3 qts of MTF in a 1.6 qt transmissiom?
Just had my transmission fluid and differential fluid changed at the local Honda dealer this morning. MY2002, 12,000 miles. Was getting occasional 2nd gear grind so thought I would try having fluid changed. Had diff oil changed at same time for the hell of it.
Details:
Diff service
Labor: $36
2 washers: $4.12
Mobile 1 75/90 : $17.50
Transmission service:
Labor: $24.00
3 washers: $1.29
3 quarts Honda MTF: $13.98
GRAND TOTAL: $104.65 with tax.
While in the waiting room, reading my owner's manual, I read that the transmission capacity was 1.6 quarts. When the bill showed 3 quarts used, I questioned it and the service manager went to the parts department. They confirmed that the quantity should be 3 quarts. Manager then went to the technician who did the work and he confirmed he had put almost 3 quarts in the transmission before it showed full.
Is the owner's manual wrong? Did the transmission get overfilled? Your thoughts?
By the way, the transmission feels smoother now.
Details:
Diff service
Labor: $36
2 washers: $4.12
Labor: $24.00
3 washers: $1.29
Go back and bitch-slap the fools that supposedly confirmed this info.
You can have dozens of owners on this site tell you, they overfilled your tranny - big time. Either that or they lied to you and milked you for some extra fluid.
Geez, who do they think they are fooling?
I smell refund!!!!!
p.s. Don't drive it long like that.
I smell refund!!!!!
Originally posted by mwy23
3 washers for a tranny that only uses 2?
I just changed my transmission fluid this weekend (it's easy) and it took about 1.7 quarts. I even tilted the car a bit to put just a touch more fluid in. No way you could get 3 quarts in there unless you put the car on its side, or maybe leave the drain bolt out for the 1st quart. Morons.
$17.50 for mobil one?
Hockey
3 quarts is somewhat understandable... they could have emptied the tranny, plugged up the drain, filled with 1 quart, then drained that (in an attempt to drain all old fluid or at least dilute it) then plug it up and continue on...
i guess that's why they needed 3 washers? use two on the drain bolt (once for the fill/drain to dilute, once for the final fill) but they could have used the original washer for the first fill/drain.
Hockey plus a little cash on the side is always good
aero, if i were you, i'd switch out the clutch fluid as well.
In addition, we (as owners) don't get hosed like this.
Everyone is Happy
Have you ever known a dealership to care about the cleanliness of your tranny enough to go through that step?
