2008 stock suspension setup better than 2007?
The differences would be just noticeable in a back-to-back test on a race track. A 2007 or 2008 S2000's OEM shocks will no longer be at their original settings, bushings will have worn, etc.
Most people modify to different shocks/springs unless they are competing in a class that requires stock springs, such as B/Street. I posted a link to a presentation that discusses the difference between different shocks and their designs. Similar to virtually any professional race car, the OEM shocks and most third party (except KW and Koni) are monotube. The OEM shocks and some others determined that the short rear shocks don't have enough volume for the nitrogen, especially if lowered. The OEM shocks have a piggyback chamber in the rear, Penske recommends an 8300 with external reservoir if lowered. PSI did it for their S2000 version of the Ohlins TTX shock.
That's the problem, you can't tell important info in a test drive or in someone else's car.
Funny, I have an E36 M3 and am looking to replace it with an S2k. Previously I had a miata. I want a very neutral car, one that doesn't understeer in the sweepers or in the slaloms on the odd autoX day. If I keep the S2k long term I'll set it up for AutoX, but I prefer to keep it stock in the mean time. I prefer an 06 or newer due to the updates, but also prefer neutral handling.
It sound's like either of them will need some upgrades for the type of handling I want, but with only 1.2% shift in front bias between the years, it's not a big difference between 07 and 08.
Great info!
Great info!
I have a MY00 which everyone said would oversteer, but that wasn't what I found. The rear end did move around due to toe changes over bumps in turns, but otherwise it understeered - just like most cars with factory suspension settings. Going to 3.2 deg up front made things a lot better on the track. And that's for the MY00. I think you'll find the later years you're considering will understeer when pushed hard.
In summary, I wouldn't worry too much about the suspension differences between those two years as you're likely to make other changes to meet your goal of no understeer on the autocross course.
ragtophardtop (04-14-2020)
energetic
09-30-2007 10:18 PM
