2004-2005 Radio cover plate
Old 01-07-2005 | 02:35 PM
richpass's Avatar
Default 2004-2005 Radio cover plate
Is the radio cover plate for 2004-2005 a direct replacement for the 2000-2003 cover?
Old 01-07-2005 | 02:48 PM
Skimad57's Avatar
Yes, same mounting pins.
Old 01-08-2005 | 06:27 AM
s2kbrian's Avatar
yes all the same
Old 01-08-2005 | 10:00 AM
Mossad's Avatar
Er, I heard from people who've done the conversion that, for some reason, the spring from the pre-04 bracket is too weak to handle the new door. This results in the door not springing open when you push on it. Is this true?
Old 01-09-2005 | 02:14 AM
sanee515's Avatar
anyone who has done the conversion want to donate their old door to me? or sell it cheap? please pm me. thank you. it would help A LOT!
Old 01-09-2005 | 07:44 AM
User 53024's Avatar
I've got an '02 and did the swap at Christmas. No problem with the door opening at all. What you heard didn't make sense really, as the spring is just an assist. Gravity is doing most of the work anyway.
Old 01-09-2005 | 10:04 AM
s2ka's Avatar
I did the swap, worked just like stock. Unfortunately the color of the silver door kind of clashes with the graphite trim from the 02-03 cars so I took it off. It's sitting in my garage, make offer if you need a new 04 door, still in the factory wrapper.
Old 03-01-2005 | 03:15 PM
d.h's Avatar
d.h
For the conversion, I have heard that you remove the whole trim of the radio lid including the air vent. I have also heard you can just remove the radio lid without removing the whole trim. So which is it, or does both way work?
Old 03-01-2005 | 03:30 PM
Wisconsin S2k's Avatar
it was not difficult to do at all. yes i believe you have to remove the outer trim, but it's extremely easy. i'd say the entire swap took me 15 minutes.
https://www.s2ki.com/forums/index.php?showtopic=251894
Old 03-01-2005 | 03:34 PM
triumph87's Avatar
It is very easy. and iit is a direct replacement it took me no more than 10 minutes to do it.
molys2000
09-12-2008 05:02 AM
par4dox
07-25-2006 09:37 PM
toosoonjunior
11-27-2004 04:41 AM
ayelien
06-08-2004 10:38 AM
wagnerb
01-29-2002 11:52 AM
Quick Reply: 2004-2005 Radio cover plate
