1st oil change
Old 12-26-2005, 09:28 PM
22calbr's Avatar
Default 1st oil change
hey fellas. happy holidays to all. just a quick noob question for yall. my car is 4 mos old with 2800 miles on the dial. i think honda recommends first oil change around 3750 to let the moli or whatever its called set in. should i change my oil soon or should i wait for the 3750. thanks for the help.
Old 12-26-2005, 11:54 PM
Enthralled's Avatar
I changed mine at 3k.
Old 12-27-2005, 04:39 AM
mosesbotbol's Avatar
I don't feel it really makes a difference. These engines are just about bulletproof.
I would consider the miles/ hours the engine has run and decide from there. If your mileage is all local- go ahead, if all highway- wait.
Old 12-27-2005, 04:46 AM
rai
rai's Avatar
No reason to change it before 3000 mi IMO.
I'd probably let it go to 3000-3750 mi.
Old 12-27-2005, 07:30 AM
EDness's Avatar
i just changed mine 3 weeks ago at 4200 miles...but i waited 8 months.
Old 12-27-2005, 07:44 AM
dolebludger's Avatar
When in doubt, go with factory recommendations.
Thanks,
Richard
Old 12-27-2005, 08:39 AM
Cyclon36's Avatar
I'm pretty sure the recommended period for the first oil change is over 4k. Anyway, the reason is b/c the first oil that's in your car is a break in fluid that has high moly content and other things to streangthen your working bits and make sure everything seats right. I would go with the recommended interval in your manual and just stick to that.
Old 12-27-2005, 09:41 AM
cap1's Avatar
Old 12-27-2005, 10:00 AM
SD_S2K's Avatar
recommended interval is like 6-7k I believe for first oil change to let that fluid really bind right ...
I always believe the manufacturer to be right, but should you really go 7000 miles till your first oil change?
Old 12-27-2005, 10:47 AM
wanabe's Avatar
changed mine at 5,000 miles and that was when the car was about 10 mos old... the oil did not look bad-
then changed again a little over 9 mos later when the car had 10k miles on it and went to synthetic then.
Quick Reply: 1st oil change
