1st 10K Miles in a 2007
My 07 S2K is my 1st Honda sport car and has been the best drop-top car Ive had: much more reliable than my C-5 Corvette and 355 Ferrari.
Wish it had adjustable steering and a 7th gear. Still not used to cruising at 4K Rpm for 3 hours straight every weekend heading back home.
Hopefully wont have to have a Valve adjustment until 100K?
There are a lot of '06+ cars that have had tight valves after just 25k miles. I would rather adjust them than running the risk of burning a valve.
Honda just adjusted the valves on my '01. It was $237 with parts (new gaskets) and labor. It's an inexpensive job.
Edit: BTW, I'm quoting Billman250 on 06+ cars having an increased instance of tight valves. I don't have any first hand experience.
Welcome! quite a stable you had. but im glad to hear such high praises from an owner who owns/owned exotics. There are some things you should research as preventative measure. as valve adjustments go i would do a valve adjustment once a season, if you work on the car yourself. but here is a good read and will help you make a decision on how often you should get it done.
https://www.s2ki.com/s2000/topic/106...ners-dbw-cars/
and there is a DIY for almost every TSB and procedure there is for this car.
Here are the things to look for and address.
https://www.s2ki.com/s2000/topic/681...ons-1999-2009/
happy motoring and enjoy it.
Here is the post from Billman regarding 06-09 valve issues: https://www.s2ki.com/s2000/topic/106...ners-dbw-cars/ I'm definitely getting mine done this spring (just got the car and it has 38k miles.)
Not sure about the valve adjustment, I've got an 01' and haven't yet needed one.
hyperpm
05-17-2003 07:39 AM
