1QT 700 miles
1QT 700 miles
First of i have a MY03 with 83,XXX miles and i run Mobile-1 10w-30
I have burnt a whole QT of oil in 700 miles with a moderate amount of vtec'ing
nothing out of the ordinary.....
i was told to replace my pcv valve that should take care of most of the oil consumption is that true?
,thanks
,thanks
Change oil brands and get the new PCV valve. I would recommend krank vents last if the first two options don't considerably reduce and/or stop the consumption.
If you're a 3000 mile oil changer then you don't need to use synthetic (if you do you're wasting it). If you like to wait longer between intervals then any brand name synthetic will do, try Pennzoil Platinum or even a regular dino oil and see if consumption is reduced.
^ Not a big fan of Pennzoil Platinum. I've used Mobil 1, Valvoline Synpower, Pennzoil Platinum, and Royal Purple. Here's how I would rank them:
1. Royal Purple
2. Valvoline Synpower
3. Mobil 1 Synthetic
4. Pennzoil Platinum
1. Royal Purple
I burned oil like crazy with Mobil1 with my S2000 and ITR. Try switching to Amsoil, RP or Castrol. I will not use Mobil1 again. Even rumors of it not being a true synthetic (but lets not get into that discussion here).
Try those other brands and see what happens.
1. Royal Purple
1. Royal Purple
Pennzoil Platinum will rival Mobil1 in every category, UOAs with PP trend less iron over the same milage interval compared to M1, and Pennzoil Platinum is just as available as Mobil1. Pennzoil Platinum is, in almost all respects, equal or superior to M1.
Come packing some proof and maybe I'll put some faith in your comments. I seem to remember you posting some crazy claim about engine oil in the past...
Originally Posted by Aze85,Aug 8 2007, 04:18 PM
krank vents solve the oil burining/consumption problem completely
Lazyrider69
09-09-2014 04:11 PM
