1/4 mile with 4.77
I did a search and COULD NOT find what I'm looking for. My question is this. Has anyone ever Drag raced the 1320 using the 4.77 gears? I'm contemplating a gear set but I'm stuck between 4.44's and 4.77's. The highway rpm
You might be better off going with the 4.44 I have read numerous threads talking about this same subject. The general idea was that with the 4.77 you will have an extra shift. And the time that it takes to make that extra shift, no matter how fast you are, negates the benefits of the 4.77 because you are shifting more often.
well, Let me TRY to figure this out for you. No promises.
Gear Max Speed in that gear (9000RPMs)
1st 37.1 MPH
2nd 56.8 MPH
3rd 78.4 MPH
4th 100 MPH
5th 119.7 MPH
6th 143.3 MPH
I don't know if this is correct, but I think it's close. All numbers are with a 4.77 Final Gear. I hope this helps at least a little. I would say that you would definately have a extra shift. Go with the 4.44s. Good luck with your gears.
1st 37.1 MPH
2nd 56.8 MPH
3rd 78.4 MPH
4th 100 MPH
5th 119.7 MPH
6th 143.3 MPH
