1-2 grind for 2001 s2000's?
#21
Originally posted by s2ktaxi
The transmission is more likely to grind if the transmission oil is not up to temps.
The reason is because the parts expand at different rates when hot and the sleeve is even more likely to force the gears together before the synchos have matched gear speed. The hot lube is thinner and does less to smooth the premature engagement.
I know there are some with trouble free cars that can not relate to this real problem, but it is real. As for those that think they can drive better and avoid it, ok maybe you can, but I have been driving high performance manual transmissions (without grinding) for over 30 years, and needed the TSB work on mine to stop grinding.
#27
An update on my car: Today I had a leisurely drive in the country and when I came back into the city, I had 2 1-2 grinds. This happened when the car was hot (as malachi mentioned) and it happened, even though I have been SUPER careful about shifting (i had the clutch way depressed before I touched the shifter). If this becomes a regular problem, I may think about going in and having a dealer look at it.....I don't want to cause any damage that doesn't have to be done.
#28
I have an updated 2000 model. I ground 1-2 several times a week before the transmission fix (TSB). I'm not convinced that it is completely cured because I ground 1-2 once in Florida during the week I was down there. It takes hot weather for the worst grinding, so I am waiting for summer to draw conclusions.
