04+ transmission
Originally Posted by Emil St-Hilaire,Feb 3 2006, 01:57 PM
So,ideal set-up would be an AP-1,+ gears + AP-2 tranny???
The best of both world.!!!
Crunching some numbers...
An AP1 with AP2 transmission and 4.44 gears is actually geared almost identically through the first 4 gears as having 4.56 gears (11.5% more aggressive/shorter than stock). However in 6th gear it is just 6% more aggressive/shorter than stock. Sounds real nice to me!
*Note: You may not want to put too much faith in my calculations*
6th gear is almost identical. The geared top speed for an AP1 with an AP2 tranny and 4.44 FD gears is only 3 mph faster. So, you might say that 6th is a hair less aggressive in accelerative capabilities. It will give you slightly less cruising rpm at the same road speed, which I consider as a bonus.
