E36 M3 Vs. S2k
#101
Originally posted by r6e36
'95 M3 has a 3.0L ODB1 engine rated at 240 bhp 6000 rpm and 225 lb-ft 4250 rpm
'96-'99 M3 has a 3.2L ODB2 engine rated at 240 bhp @ 6000 rpm and 236 lb-ft @ 3800 rpm
but it's commonly known that the 3.2l motor puts out more like 250HP base on dyno runs
I am still debating wether if I should get a E46 M3 convertible to replace my car or just keep my E36 M3 and get a new S2k. What do you guys think?
i own both cars and prefer to have the two rather than a new m3. the m3 is practical enough for everyday stuff and is still a good track car and other "performance driving" excursions. the s2000 is a wonderful toy that is going to make a better track car to learn with soon enough.
bassem
#102
Another data point on this issue.
Karl and Fred at have Active Autowerke probably have more dyno time on E36 M3's than any other folks on the planet (dyno pulls). They use a true loading dyno, a Mustang dyno, rather than a dynojet which is an inertial dyno. As such, their graphs tend to show lower hp ratings than what you'll see from other tuners (as well as based on my personal experience).
They dyno'd at least one S2000, and it put down about 185. The 3.2L motors tend to put down right around 200 stock. The S2000 is rated at 240hp, as is the 3.2L.
Assuming similar/same drivetrain losses b/t the two vehicles, and assuming that the S2000 actually makes 240 hp, then one can only conclude that the 3.2L motors put out more on the order of 250 hp.
My car's dyno synchs up with this; as I said above mine put out 214 stock on a dynojet (234 now), which is ~10-15 more than the common S2000 dynos that have been posted here.
#103
I agree about the different output on different type of dynos. That is why it's very important to mention what type of dyno was used when posting dyno #s.
#104
#105
negcamber, you can compare all the charts you want. But if these dyno pulls were not done in the same day and same dyno they cannot be compared. Also have in mind that aftermarket vendor will always use the lowest HP chart they find so that they can show a bigger HP gain with their mods.
#106
#107
Not my logic, data from one of the premier bimmer tuners. When I considered buying an M3, I contacted Active. When I told them what I drove, they said 'you want to know what the S2000s we've had in here dyno'd?'
It's pretty common knowledge that the difference b/t the 3.2 and the 3.0 is not peak hp, but mid range tq. Typically 10-15 ft lbs difference.
Anyway, bimmers are not the only car to hit the street with conservative hp numbers, nor are S2ks the only to have optimistic (or perhaps just accurate) hp numbers.
