S2000 Street Encounters Stories of on-the-road exploits and encounters.
350z vs s2000
Old 01-09-2006, 11:20 AM
  #41
Johnny Sack's Avatar
IF AUTO 350'S ARE RUNNING 13.6'S THEN HELL I AM RUNNING 12.6'S CAUSE I BEND OVER AUtO 350'S WITH MODS!
Old 01-09-2006, 12:26 PM
  #42
Z33 KRN's Avatar
sigh... I give up, I was never saying that a 350z or s2k is faster... im just tryin to show some info about 350z. especially the autos. most people that drive autos just mash the gas when it comes to races which makes the car alot slower than it really is. i cant even crack 13'z unless I put it into manual mode, I usually actually drop around .4-.6 off my time.
Old 01-09-2006, 02:27 PM
  #43
Wisconsin S2k's Avatar
z33 krn is making good points here. some people need to stop trying to come up with something between the lines.
Old 01-09-2006, 02:37 PM
  #44
DIDNT MEAN TO SOUND LIKE AN ASS
Old 01-09-2006, 02:38 PM
  #45
350Z OVERALL =
Old 01-09-2006, 07:40 PM
  #46
zulater's Avatar
wisconsin i know i said "more top end" which was my error. You see I acknowledge when I am wrong and I can deal with it like an adult. The only way weight affects top speed is friction and thats a minuscule factor.... agreed. Weight affects acceleration up to top speed.
We can argue about which car is faster around a track all day long. And even then it's going to come down to the track and driver skill. So that's a moot point.
In a straight line it would be absurd to claim the cars are equally fast. You think because you can run the quarter close to what a Z does that you can continue to hang up into the triple digits? You're fooling yourself if you think so. You simply don't have the power:weight and aerodynamics to do so. Your gearing isn't going to do you any favors at those speeds either. The Z hits the 159 limiter with ease and has more power to go.
Old 01-09-2006, 08:38 PM
  #47
YellowS2kPwr's Avatar
You're the one who turned this into a pissing fest, so congrats on that. I think you're quite an antagonistic little man so I hope I'm pushing your little buttons. You deserve to be flamed. Good luck with your wet dream.
Why do you come here and ASSUME anyone of us is willing to race into the triple digits? By the way... wtf is this 159 mph limiter? Last I knew, a 350z could hit 165 and there was no limiter...
P.S. I think it's time for you to give up...
Old 01-09-2006, 10:54 PM
  #48
Z33 KRN's Avatar
the Z has a speed limiter. its somewhere in the deep 150'z... if u think the Z or the S really has alot of go after around 120ish u really need to drive a higher powered car.
Old 01-09-2006, 11:15 PM
  #49
psychoazn's Avatar
1. the 350z has more power, as well as having better aerodynamics. (fairly obvious, compare numbers, and the S is a convertable...). Therefore, the 350z should definately have more top end.
2. as for turning, as you cant do a 'paper comparison', I wont delve into it.
3. for low end acceleration, the S is geared very agressively, and weighs less. Thus, this *could* make up for lesser power. In this particular case, it would seem that the 350z and S2000 are about equal in the 1/4.
Old 01-10-2006, 12:17 AM
  #50
NeO SAMuRAI's Avatar
All points that Wis has already covered.
#2 - S2K is superior at Auto-X, and most road courses...I'd say it does better @ 'turning'.
Quick Reply: 350z vs s2000
