S2000 Street Encounters Stories of on-the-road exploits and encounters.
1/4 mile times?
Old 03-25-2006, 10:42 AM
  #121
NNY S2k's Avatar
Originally Posted by Wisconsin S2k,Mar 25 2006, 09:23 AM
all of the timeslips get posted in my original post, so dont worry about them being missed. when people add them, i save them, and then re-post them in the very first post.
I see mine is still on pg 2
Old 03-26-2006, 01:22 PM
  #122
Cagedheat's Avatar
Alright, got done running this weekend at the track, trying to verify my 13.64 run. I wasnt able to beat that time but got pretty close...
At the start of the day (first 3-4 runs) I tried using 25psi, but my tires would grab too quickly and bog the motor down to around 3K... NO POWER sucked. I had to launch at 8000 to prevent the bog. that didnt workout too well, I kept getting 14.0, 14.1, 13.9... no good. So I filled the tires up to 35psi and bam.. I got a 13.77, 13.76, and a 13.70.
I really really need new tires! It was hard to find the correct balance between good traction & good launch speed.
Old 03-26-2006, 01:54 PM
  #123
Wisconsin S2k's Avatar
i'll have to go back and look
Old 03-26-2006, 01:55 PM
  #124
good deal.
Old 03-28-2006, 05:55 AM
  #125
24s2k7's Avatar
How much does the 60' effect the 1/4? Something is wrong with my alignment and I am having troubles launching. Way too much camber, my back end even slides out really bad when I shift into 2nd so you know I slide around on a launch. Anyways, I got a 2.5 60' and a 14.3 1/4. How bad does the 60' change your 1/4?
Old 03-28-2006, 09:08 AM
  #126
Cagedheat's Avatar
Alot! I dont know the exact numbers, but if I could get my 60ft below 2.0 I would be deep into the 13.5's.
Also if your doing a 2.5 60ft, you really need to work on your throttle work. a 2.5 would indicate that your keeping your foot way too into it, or launching way too high for your car. Lower to tire pressure to about 28-30 and see what happens. But you've gotta be able to feel the traction point with your foot... then floor it!
Old 03-28-2006, 09:21 AM
  #127
RED MX5's Avatar
[QUOTE=24s2k7,Mar 28 2006, 09:55 AM]How much does the 60' effect the 1/4?
Old 03-28-2006, 11:30 AM
  #128
2QYK4U's Avatar
For those who have a fair amount of experience drag racing your S2000, when you launch the car at say 6000 rpms and side step the clutch, are you:
1. Keeping the gas pedal in the same position when you reached 6000 and dumped it
2. Letting up on the gas pedal
3. Feathering the gas pedal (slowly applying more gas)
Old 03-28-2006, 11:33 AM
  #129
YellowS2kPwr's Avatar
Neither. You press it all the way down. (Unless you've launched too high then you feather for a bit until you regain traction then all the way down).
Old 03-28-2006, 11:38 AM
  #130
you should be flooring it. you feather the gas if you have too much wheelspin
Quick Reply: 1/4 mile times?
