Yokohama Advan 032r set up questions
I just picked up a set of Yokohama Advan 032r's (hard compound) in f205/r245-16 mounted on stock wheels. I have a MY02 running on stock springs/sway bars and my car is not lowered. Other than to and from the track I will not use these tires on the street. Any experience you have about some baseline tire pressures or alignment settings would be appreciated . Note on alignment-This is my daily driver so I can't go for a full aggressive track alignment but if these tires like/dislike anything special I can make some compromises for that.
Hope some of you track junkies can help because my similar post in "Tires and Wheels" forum got ZERO response. Thanks, MarchHare.
I don't know if any of the die-hard track junkies have tried the A032Rs yet. One note on the alignment: you'll spend MUCH more money on track tires, so your best bet is to get an alignment that optimizes their wear rates and just accept the somewhat accelerated street wear.
brent_strong
06-29-2009 01:04 PM
Nickfromny
09-15-2005 10:54 AM
Jim Schweigert
10-29-2003 04:36 PM
