Will 245/45 17" on CE28N fit up front?
Old 03-09-2004, 04:07 PM
davepk's Avatar
Its the wrong direction.
Old 03-09-2004, 04:16 PM
rlaifatt's Avatar
Dave, when you say the rear rim (9") can be used up front with spacers, could you clarify? As I have 2 sets of rims, I could run the 9" on all four corners
Old 03-09-2004, 04:23 PM
rlaifatt's Avatar
[QUOTE]Originally posted by Asura
Have you considered going with a 18x10-10.5 rear?
Old 03-09-2004, 04:48 PM
davepk's Avatar
Richard,
The center bore on the rear wheels is smaller than the front wheels. 2.5" vs 2.75" i believe or something similar. Either way a rear wheel wont fit flush onto a front hub because of the smalll center bore. If you place a spacer on the front hub then the rear wheel can sit flush against it but it will stick out by however thick the spacer is.
What i'm suggesting is that you widen the center bore of your CE28N so that it sits flush against your front hub without the use of a spacer.
Old 03-09-2004, 06:55 PM
rlaifatt's Avatar
Thanks Dave and everyone for your input. I'll do some more analysis before deciding what to do.
S2Kitt
01-03-2009 08:10 AM
S2K23
10-06-2008 09:06 AM
customcamry
10-06-2007 12:06 PM
civicson234
07-21-2007 02:00 PM
JC_s2k
02-08-2006 09:42 AM
Quick Reply: Will 245/45 17" on CE28N fit up front?
