Wheel bearing upgrade?
Which part are you suggesting replacement?
So the hub had some very odd looking fatigue marks on it, got a new hub and bearing. Got the sindle off the car in 18 minutes with hand tools lol. I'll post pics later ShocK.
Originally Posted by caffeinefr3e' timestamp='1303703142' post='20503347
Have you replaced your rear hubs? Replacing only the wheel bearings and leaving the worn hub is going to accelerate the wear of your new bearings.
One thing I am considering is taking the bearing to a place in town here called "Bearings and Drives Inc" and seeing if they can reassemble the bearing using some Redline CV-2 grease and maintain the sealed integrity of the bearing.
I did some bearing research after reading robrob's writeup. Here's what I found:
- OEM bearings are made by NSK, $55.51 from HPD or ~$50 from http://www.partsgeek.com/mmparts/whe...nda/s2000.html
- Other good wheel bearing makers=SFK, FAG (german), Koyo, and Timken. Apparently Timken sources parts from various locations and quality may vary but generally they're good.
- Amazon has S2k spec Timken bearings for ~$30 (bought 2 as spares): http://www.amazon.com/gp/product/B000BZ5108
So here we are again, back at square one. I attended a track day in early July and have yet another fried wheel bearing, I can hear it clicking when I change directions in a parking lot. I think I'm going to vent the rear brakes and see if that solves the issue of frying the bearings seals. Of course I'll have to install a new wheel bearing again lol... I got smart and bought it from the dealer, so this time I can return it as a defective part.
two words - run out
it's something not often checked especially when replacing rear disks and it's an indicator somethings wrong.
and to answer your question - yes there are much better options available
http://www.ceramicbearing.com/cerami...rformance.html
