what size wheels and tires u prefer for race track
Old 11-22-2004, 01:09 PM
s2kboy03's Avatar
Default what size wheels and tires u prefer for race track
16" or 17"? and which tire and size performs best??
Old 11-22-2004, 01:16 PM
rlaifatt's Avatar
Start with the tires and the choice would be Toyo RA1's shaved. Because of the sizes available, first choice would be 16" (225/245). For 17's, the ideal sizes would be 225/45 - 255/40, but RA1's don't come in 225/45, so you would have to go 235/45 - 255/40 or 235/45 - 275/40 (some rubbing).
Old 11-22-2004, 02:44 PM
Triple-H's Avatar
I agree about the Toyo RA-1s, but not all of us like the 225/55-16 upfront. With a stock suspension plus additional bracing I prefer the 205/55-16 up front and the 245/45 in the back.
Old 11-22-2004, 03:05 PM
billyblast's Avatar
Please excuse the not-knowing-esque of me but... when running 16x7 and 16x8 wheels with stock suspension, what effect does 225/50 up front have on the car as opposed to running 205/55 with stock suspension? Thanks guys...
Old 11-22-2004, 03:13 PM
FF2Skip's Avatar
Assuming you are referring to the same model tire for the comparison, the larger tire will increase the potential for oversteer versus the smaller one.
Old 11-22-2004, 03:14 PM
mikegarrison's Avatar
When you go around a corner faster than your car will make it, which end starts to slide first? If you add grip on the front (wider tires), it tends to make the back start to slide before the front. Oversteer.
Old 11-22-2004, 03:24 PM
billyblast's Avatar
Got it !!! Thanks Guys
Old 11-22-2004, 06:41 PM
PedalFaster's Avatar
If you're new to DEs (or don't know what DE stands for ), you'd be much, muuuuuuuuch better off skipping getting new wheels and tires, and spending that money on some instructed sessions instead. A good driver on street rubber will murder a newbie driver on race rubber.
Steve
Old 11-22-2004, 07:28 PM
Administrator
Ludedude's Avatar
Old 11-23-2004, 07:34 AM
sfphinkterMC's Avatar
if you are on the race track...u should have race tires
same for brake pads and fluid
Quick Reply: what size wheels and tires u prefer for race track
