What kind of brake fluid should I buy?
You don't want to get to that point, cuz it means you've boiled your fluid. Not a good thing at 130mph going into a hard braking zone. You should change regularly (no less than once a year) if you have DOT 4 fluid in. Some people change all or part each race or track day.
And, for the record, I've never had any trouble with ATE Super Blue. I have Motul in the car at the moment, because I alternate the two (to change color), but I've reached the point where the brakes are being asked to do more than they can (I note a bit of fade), with no sign of boiling.
Originally Posted by Stephenopoly,Feb 26 2007, 10:47 AM
Gonna ask a newb question, I'm currently running ATE BLue, How do you know when you need to change out your brake fluid?
Also for the record, I have yet to have trouble with ATE super blue.
Bassem
Former Sponsor
Ive actually run the Valvoline Syntech im my past 2 cars. Never boiled once. The RSX i had and STI, both had brembo brakes. Both were tracked regularly. The RSX even went 1 hour straight on the track with no reduction in brakes. Never had issues with the heavier STI either. Seems to do very well for a more common fluid available at most auto parts stores.
^^Yes, DOT 4 fluid picks up moisture quickly. But if you could press your brake pedal to the floor in an autocross, you had something else up. You could almost use water as brake fluid without boiling it is a typical autocross. I bleed each winter, have done many track days and autocrosses each year (and it rains a bit in Seattle), I brake hard on a track which is hard on brakes, and I've never had an issue with ATE Super Blue boiling.
Any way the spongy brake could be related? I suppose of the brakes had already started binding at that autocross (and it just took me a few months to notice it on the street), I could have heated up the rears sufficiently to boil one side or the other.
Not that things FELT that bad-- I set the FTD at that autocross!
I don't know. You may have a leak, which only shows up on hard braking. You may have been too low on fluid. Certainly, if the boots and seals were not in good shape, that could affect the rate at which the fluid was being compromised, but autocross is so easy on brakes that spongy brakes at an autocross, to me, indicates something wrong with your braking system, not just needing a full bleed. You're never on the brakes for more than a couple of seconds consecutively in an autocross (especially if you're setting FTD); there's just not time to overheat healthy brakes.
