What is a Decent coil over for the street on the cheap;)
Old 01-30-2014, 08:29 AM
S2KPUDDYDAD's Avatar
A lot of great options and info, I will keep my eye on the forum for a low use used setup.
Is there a big difference between the Pss and the PS9? I think I will budget $1,000 to $1,300 new and $700 to $900 for good used.
Old 01-30-2014, 09:00 AM
iamxpl's Avatar
from what i can tell the difference is that PSS9 has adjustability with compression?
Old 01-30-2014, 09:10 AM
takchi's Avatar
I believe the difference is PSS9 has compression/rebound adjustment (1-way) and PSS doesn't.
Old 01-30-2014, 10:04 AM
Does anyone know if the PSS set will adjust the car ride height down 1.5" from stock?
Old 01-30-2014, 10:09 AM
This how the car sits right now on stock shocks and eibach springs, I would like to come down maybe another 1/2"
Attached Thumbnails What is a Decent coil over for the street on the cheap;)-hardtop-2.jpg
Old 01-30-2014, 10:15 AM
BlueBarchetta's Avatar
.75-1" seems to be the most popular drop with PSS/pss9. I was at about 1" with pss9's. Honestly, more than that you might start to introduce rubbing issues.
FYI, I just sold my lightly used PSS9s for 900. If you're careful and patient, I think that's a very typical price.
Old 01-30-2014, 10:30 AM
iamxpl's Avatar
^^^ what he said. the PSS9 are particularly stiff so a decent dip might get you to rub.
Old 01-30-2014, 10:34 AM
DaGou's Avatar
Thanks guys for the good info. The Ps9 setup looks to be in the $1,500 range, maybe $300/400 less than the stock c/r Swift setup. My thoughts, I should just spend the few hundred and get the Ps9 since there is greater adjustability.
I also have a WAY over kill for the street differential, don't figure
PuddyMod Stage 4 case, OSGiken 1.5way LSD 752kg pressure ring, Richmond 4.57 gears, and high capacity (41oz) PuddyMod diff cover.
Love this diff, improved acceleration, smooth progressive locking of the LSD and quiet operation other than a little gear whine
I wish you tried to see me a PuddyMod Diff cover when you did my diff rebuild to 3.9 gears! I would have went for it for sure.
Old 01-30-2014, 10:58 AM
Sorry about that, the one on my car is the prototype
Old 01-30-2014, 11:17 AM
1nate7's Avatar
Keeping your Eibach springs and just picking up a set of Koni yellows might be your best option. You can run them on the lower perch which will give you that 1/2" you are looking for.
Quick Reply: What is a Decent coil over for the street on the cheap;)
