Vortex generators on hardtop?
Old 04-01-2009 | 01:06 PM
Sobe_Death's Avatar
Default Vortex generators on hardtop?
I have noticed that most people are placing their wings pretty high up to get them into cleaner airflow on the S and I was wondering if anyone has looked into adding a row of vortex generators along the back of their hardtop? I would think they would be pretty effective at bringing the turbulent flow closer to the trunk lid...
Any thoughts?
Old 04-01-2009 | 01:17 PM
mikegarrison's Avatar
VGs tend to energize the boundary layer by entraining higher velocity air into it. Of course that causes drag.
I suppose you could try it and see, but what are you trying to do?
Old 04-01-2009 | 01:47 PM
krazik's Avatar
Administrator
Old 04-01-2009 | 02:00 PM
Sobe_Death's Avatar
I realize that they cause drag, but for the most part their benefits outweigh the small amount of drag created-IF they are properly installed/designed.
My line of thinking is this:
In a typical S2000's track setup, there is a hardtop with a pretty tall wing installed. The wing is tall to keep the airfoil in "clean" airflow since there is a nasty low pressure area right behind the top creating all kinds of turbulent flow. The vortex generators introduce a turbulent boudary layer which helps keep flow from separating after the rear roofline. This, in turn, should reduce the need to have a wing mounted so high up.
At least that is what's going through my head right now...
Old 04-01-2009 | 02:21 PM
SpitfireS's Avatar
The text is in Dutch but its all in the picture.
It worked for speed ice skating.
So well they got banned.
As far as I know.
They don't go that fast but they also don't have 240+ hp.
So every kW counts.
Old 04-01-2009 | 02:28 PM
Those are trip strips, not VGs.
The difference is that trip strips are intended to make a laminar boundary layer flow turbulent. VGs will do that too, but they are really more intended to bring high energy flow into an already turbulent boundary layer.
Old 04-01-2009 | 02:42 PM
S2Kage's Avatar
funny u bring this up, I actually have a carbon fiber VG for an STI sitting in my garage that i was saving for when I got my hardtop
Old 04-01-2009 | 07:19 PM
cracknut's Avatar
Mitsubishi published an interesting white paper on the topic for the Evo 7/8/9 chassis. The Evo has a tall greenhouse and a steep rear window and the VGs definitely help reduce drag *and* increase the effectiveness of the rear wing.
However, note that they tried myriad size/position combinations to find the optimum setup.
http://www.mitsubishi-motors.com/corporate...2004/16E_03.pdf
Old 04-01-2009 | 09:15 PM
PedalFaster's Avatar
Setting aside for a moment the debate over whether vortex generators would allow you to run a shorter wing -- why is running a shorter wing desirable in the first place?
Old 04-02-2009 | 07:34 AM
INTJ's Avatar
Cool paper
Quick Reply: Vortex generators on hardtop?
