Turning Over Rotors
Old 04-30-2012, 08:56 AM
chuhsi's Avatar
i've never turned s2000 rotors before.
just ensure that all the brake compounds are compatible. if not, turn the rotors or drive around with your race pads to scrape off the the old transfer layer (I do option 2)
Old 04-30-2012, 10:45 AM
OVER 9000!'s Avatar
Does anyone know if the Hawk HP+ pads are made of abrasive materials and will be able to scrape off the old transfer layer at low temps? I have already bedded them in, but I will check the rotors later today for uneven pad deposits. Will I be still be able to scrape off the new deposits as well as the old transfer layer if I do have uneven deposits? Thanks for all the advice!
OVER 9000!'s Avatar
Originally Posted by aCab
I wouldn't turn them. Turning them makes them thinner, causing them to heat up and cool down quicker - which makes them much more prone to crack. Ask me how I know.
How many times did you have them turned?
Old 04-30-2012, 11:10 AM
robrob's Avatar
Those screws in the rotors are very soft and easy to drill out. When the head of the screw pops off remove the rotor and you can unscrew the rest of the screw with pliers. Mine actually came out by hand. The screws are not needed but if you do use them then put some anti-seize on the face and thread of the screws and they only need 7.2 lb-ft of torque. Get one of those impact drivers for the tool chest, it will come in handy many times.
Old 04-30-2012, 11:54 AM
aCab's Avatar
My friend parts out wrecked s2000s. I get the rotors for free from him from low mileage cars, get them turned for free, so free brake rotors...too bad I cracked three of them last weekend.
Like this:
Old 04-30-2012, 12:05 PM
OVER 9000!'s Avatar
^ Damn.... Would the cracking have anything to do with bigger tires since you'd have better grip and be able to brake harder increasing the temps a lot? I only have 225's all around on stock ap1 wheels.
Old 05-01-2012, 08:36 AM
thomsbrain's Avatar
Originally Posted by OVER 9000!' timestamp='1335811550' post='21656242
[quote name='aCab' timestamp='1335801334' post='21655558']
Like this:
[/quote]
I did one like that, too. It was the result of a sticky brake caliper and not enough cool-down time before stopping to cool the crazy amount of heat it had built up. Even for calipers that are working right, you gotta give them a lot of time to cool after you come off track before you stop the car.
Old 05-01-2012, 09:00 AM
jeffjanzen's Avatar
Originally Posted by macr88
You also need to buy yourself an impact driver for those screws, they're like 10-15 bucks at sears.
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
I guess they're 20-25 bucks
Hammer and chisel works too...
How to remove rotor screws
Old 05-01-2012, 09:22 AM
dan_uk's Avatar
you can drill them out to had to do that more than twice I don't put them back anymore
Old 05-01-2012, 09:50 AM
OVER 9000!'s Avatar
Originally Posted by thomsbrain
Originally Posted by aCab' timestamp='1335815695' post='21656501
[quote name='OVER 9000!' timestamp='1335811550' post='21656242']
Like this:
[/quote]
[/quote]
How long would you suggest letting them cool down? And how? Just go easy on the last lap and let them cool off before going off the track?
Quick Reply: Turning Over Rotors
