Turning Over Rotors
Old 04-29-2012, 10:22 PM
OVER 9000!'s Avatar
Default Turning Over Rotors
Hi guys, I just did the basic brake maintenance (ATE Superblue, Hawk HP+ pads, and Challenge ss brake lines) to get ready for my first track day in May and a friend highly suggested that I get my rotors turned over and that it would help prevent warping and other damage to the rotors. The problem is my friends and I could not get the two screws to budge on the front hubs and they are, for the most part, stripped. So how important is it for a track day? I am wanting to know because I'd rather pay the $50-$70 to have the screws drilled out and the rotors turned over than buy new rotors and having to pay to have the screws removed anyways. Any thoughts?
Old 04-29-2012, 10:26 PM
macr88's Avatar
Read here
https://www.s2ki.com/s2000/topic/926...ce-brake-pads/
Old 04-29-2012, 10:29 PM
macr88's Avatar
You also need to buy yourself an impact driver for those screws, they're like 10-15 bucks at sears.
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
I guess they're 20-25 bucks
Old 04-29-2012, 11:03 PM
shadow36's Avatar
for what it is worth, I never get my rotors turned. Every time I put a new set of brake pads on, I typically use a new pair of cheap-o centric blanks (they are about 25 dollars each for the fronts, and 22 for the rears). Also, after I got the set screws out of the rotors, I never replace them.
Also, just a "more you know" tid bit, it is called "getting rotors turned" because the machining process is called a "turning" operation on a rotating lathe.
Old 04-29-2012, 11:08 PM
OVER 9000!'s Avatar
Thanks mac! So essentially "cleaning the rotor with an abrasive pad", as stated in the video, is a DIY way of turning the rotors?
Old 04-29-2012, 11:14 PM
OVER 9000!'s Avatar
Have the cheap-o rotors ever given you problems?
Haha okay, thanks.
Old 04-29-2012, 11:19 PM
boyguan's Avatar
I turn rotors because it's free for me to do. If I had to pay. I'd just buy new ones once they crack. I always use the same pad compounds anyways. Cheap rotors for the win
Old 04-30-2012, 02:56 AM
CKit's Avatar
You could buy a drill bit and borrow a friend's drill and do it yourself. Once you get the screws out, most of the track people don't replace them. And you have to do it anyway at some point, right?
Old 04-30-2012, 07:45 AM
Legion's Avatar
I second the impact driver, they are incredibly useful on anything that is rusty, it will save you a lot of headaches.
Old 04-30-2012, 07:55 AM
aCab's Avatar
I wouldn't turn them. Turning them makes them thinner, causing them to heat up and cool down quicker - which makes them much more prone to crack. Ask me how I know.
Quick Reply: Turning Over Rotors
