Turbo S2000 for next race season
Old 03-05-2007, 10:07 AM
  #71
msm_s2k's Avatar
Originally Posted by krazik,Mar 5 2007, 11:55 AM
can't since I don't have mine in right now. I'm moving mine to the front hoop of the roll bar where I can reach it when I'm strapped in.
net is mounted by adding to tabs w/ holes in them to the roll cage and then its connected to the x in the door opening via some small cable.
Great, thank you!
Old 03-05-2007, 05:34 PM
  #72
gomarlins3's Avatar
Wow. That's a lot of work. Nice job.
Old 03-06-2007, 07:13 PM
  #73
DEEZ's Avatar
awesome, i cant wait to make it down to MMS this summer to watch-
Old 03-13-2007, 06:02 PM
  #74
msm_s2k's Avatar
Rylan, thanks again for the info on the kill switch. The wiring and mounting point worked perfectly.
Here are some crappy cell phone pics.
Shot of the kill switch mounted on the roll bar. Easy reach of driver and the local SCCA safety tech says location is fine.
Same angle but with the steering wheel removed so the Dash2 is more visible. Thanks Jeremy at http://fasttechlimited.com for all the help with the DL1 and Dash2!
Dunlop take off slicks from Bob Chicks. Great fit for the CCW 18x10s. Too wide for the stock fenders. Masking tape marking the cut for expanding the fenders.
Front view:
The initial cut of the fender
Finally, a shot of the rear showing the waste pipe for the turbo. The standard InlinePro kit dumps just to lower portion of the passenger side of the motor. Too close to the tranny for my liking. Rather than just dumping the hot turbo waste under the car ... we decided to run it all the way to the rear. See the small pipe where the drivers side exhaust would normally exit?
Body work should be done this week. Complete the dyno tune this coming Sat now that the AEM electronic boost control solenoid is setup. Some on track testing the following weekend ... and the SCCA regional here on 30-Mar to 1-Apr! I'll be running in SP as I saw no point in buying a set of Hoosiers just to run one SCCA regional race in ITE.
Old 03-14-2007, 07:47 PM
  #75
S2Kish's Avatar
what wing is that?
Old 03-14-2007, 08:00 PM
  #76
msm_s2k's Avatar
APR GTC 200 universal with the base extension. If you have a NASA or SCCA competition license they offer great direct pricing for racers.
Old 03-14-2007, 08:18 PM
  #77
Slows2k's Avatar
I've never seen a WG dump tube run that far..
I take it you finally got the correct wheel spacers?
Old 03-14-2007, 08:20 PM
  #78
GrandMasterKhan's Avatar
you know you should put matching tips on your wastegate dump and the exhaust. That would be fuctionally attractive.
Old 03-14-2007, 08:30 PM
  #79
Administrator
krazik's Avatar
omg
I say put a whistle tip in it.
Old 03-14-2007, 08:43 PM
  #80
msm_s2k's Avatar
You somehow managed to miss the entire point of the car.
Quick Reply: Turbo S2000 for next race season
