tracking 2.2L running it to 9k?
Old 06-08-2007, 01:18 PM
  #31
mikegarrison's Avatar
Originally Posted by mikegarrison,Jun 8 2007, 10:27 AM
I've got probably about 8000 track miles on my S2000, all with the same F20 engine that I take up close to the redline several times per lap.
I've never dynoed it, but it doesn't appear to be significantly down on power.
I should add that the engine has survived my driving better than the rest of the car....
Old 06-08-2007, 01:50 PM
  #32
gerryk's Avatar
you will run lean with an AP1 ecu on an 2.2L.
Old 06-08-2007, 01:58 PM
  #33
Scot's Avatar
the EMS system (which ever one) would override the stock ECU anyway so i guess in theory it wouldn't even matter which ECU I use other than the Rev Limiter.
Old 06-09-2007, 01:55 PM
  #34
3312DC's Avatar
scot... you need an ap1 ecu?
Old 06-09-2007, 02:52 PM
  #35
Stratocaster's Avatar
Well an AP1 ECU, with e-Manage handling the A/F ratio. That should address the lean condition.
Scot, what transmission are you running? AP1 or AP2? What gear are you in when holding redline?
Old 06-09-2007, 04:07 PM
  #36
Scot's Avatar
^ i have a full AP2 swap (engine/tranny). it depends on the track on which gear I would be holding.... at Beaver I was holding in 3rd and smacking the 8300rev limiter of my AEM.
someone posted that they are pretty sure the Greddy Emanage Ultimate can adjust the Rev Limiter so hopefully I will just go with an ap2 ECU and raise the limiter. i fear running the ap1 ecu due to going to 9k too many times by accident.
Old 06-09-2007, 04:17 PM
  #37
Well if you ran the AP1 tranny you would have a little more room (speed) in 1-4. The gearing is just a bit taller. I figured it was third
Old 06-09-2007, 04:57 PM
  #38
tinkfist's Avatar
Per Honda Challenge rules, tranny and engine must stay together (ie no back dating of either of the parts).
Old 06-09-2007, 05:12 PM
  #39
Scot's Avatar
right now I have stock rear gears.... i only shift into 6th gear for a very short time at Beaverun and probably similar at Summit Point so I should probably put in some shorter gears which would change everything..... i think the west coast guys go with 4.3's? 4.44's maybe... anything else is definately too short...
Old 06-10-2007, 02:52 AM
  #40
Thanks, I will have to read closer. I am no where near that part of my build yet.
Scot, I was talking about the differance in the AP1/2 transmissions. They changed the secondary reduction gear and lower the net ratio for 1-4 and raised it for 5-6.
oscarmamamia
07-22-2013 11:49 AM
lotus7racer
04-23-2009 04:20 AM
onepocket
09-18-2006 06:50 PM
KJ1225
08-19-2006 11:45 PM
hellothere
07-30-2004 02:44 PM
Quick Reply: tracking 2.2L running it to 9k?
