Track only S2000 Clutch advice
Old 06-13-2012, 07:04 AM
GEARHEAD's Avatar
I've been impressed with my Exedy Hyper Single. It uses a specific chromoly flywheel. Total assembly weight was basically the same as my stock clutch with 7 lb aluminum flywheel. I have been using this clutch for several years for road, track, and auto-x both NA and with ~10 psi boost. This replaced my factory clutch when NA due to a drive strap failure at the track. The Exedy has a more positive engagement than stock and is still manageable in traffic (not as easy as stock). One note - the clutch is very difficult to modulate during break-in but gets better.
Old 06-13-2012, 08:58 PM
markhs2's Avatar
OS Giken twin disc TS2A is the lightest and extremely well made. The flywheel is made specifically for the twin disc as a system.
There is much less rotational inertia as it is much smaller in diameter.
wing
02-07-2012 11:40 AM
igottademo9
12-06-2010 11:28 AM
s2kfrog
02-11-2010 08:25 PM
Scot
10-26-2008 06:53 AM
stocky
04-25-2005 10:28 AM
Quick Reply: Track only S2000 Clutch advice
