tires sizes on MY02
Old 10-27-2004 | 07:48 AM
S2000_Europe's Avatar
Default tires sizes on MY02
Hello
I have a set of Work Emotion wheels with this specs
16x7 +35mm
16x8 +45mm
Chose this wheels because they are lighter a bit wider and wheel offset are equivalent to stock wheels
I ma using this tires size following Racing an Competition FAQ
225/50
245/45
with Potenza S03 Pole Position
My concern comes because front tires looks to wide for the front wheels, rear set up looks fine.
Are this the correct tire size?
I usually go to road track, drive in twisted roads on weekends
thanks
Thanks
Old 10-27-2004 | 07:55 AM
Triple-H's Avatar
If you don't get an answer here, try posting this in S2000 Talk.
Old 10-28-2004 | 11:02 PM
thanks!!
SPA LEADER
DARK TORERO
Old 10-28-2004 | 11:32 PM
Ludedude's Avatar
Administrator
Originally Posted by S2000_Europe,Oct 27 2004, 08:48 AM
Hello
16x7 +25mm
16x8 +30mm
225/50
245/45
thanks
Thanks
Juan,
If I'm reading this correctly (+25mm, +30mm) those offsets are nowhere near the stock offsets and those wheels won't fir properly. The tire sizes are fine, I run those on stok wheels myself. Unless you run a lstiffer front swaybar though, I don't think I'd put the larger 225 tires up front.
J.P.
Old 10-29-2004 | 01:06 AM
J.P.
I wrote the wrong offet, they are 35mm / 45 mm. I am waiting for a Cusco Sway bar, 160% stiffer.
the rear wheels look right with 245, but front with 225 looks as the tire is too wide for 7" wide wheel
Juan
Old 10-29-2004 | 04:13 AM
Triple-H's Avatar
For the record I'm on OEM 16" wheels, my track set up is 205/55-16 and 245/45-16. I went with the Toyo RA-1s because Kumho did not offer a 205/55-15 and I specifically did not want to go wider on the front, thus inducing more oversteer. I seldom do autox events but I get in lots of highspeed driving schools.
Old 10-29-2004 | 05:19 AM
i have a concern:
Due to the S02 contact pach, is recomended go with 245 on the rear when you use other tire model, but the front tire keeps the same width without taking into consideration the tire brand. Why? shouldn't we get wider on the front too?
Old 10-29-2004 | 08:05 AM
cdelena's Avatar
Many of us run the 225 / 245 combination on stock wheels when using track tires. It works very well, especially if you have a slightly bigger front bar.
In my experience it is not as straight forward with street tires since many tend to have softer sidewalls. The 225 on the front does not do quite as well if it is a very soft sidewall, but I still think it works OK. The problem with 205's on the front and 245's in the rear, especially if you have a larger front bar, is too much push.. it simply screws up the balance of the car.
Since I intend to keep my front bar I have concluded that 225 / 245 still works better than other options. And yes, 225 is kinda wide for a stock front wheel, but it will mount and perform OK.
Old 10-29-2004 | 08:20 AM
twohoos's Avatar
Just look at the front tires compared to the rear: the contact patch is much much smaller, even after accounting for the smaller width. The grooves in the front tires are significantly wider than in the rear, so they are much more of a "true" 205-treadwidth tire.
Old 10-29-2004 | 09:55 AM
thanks Cdelena and 2hoos
Juan
Quick Reply: tires sizes on MY02
