Tire Pressures for Solo 2 Autocross Event?
Old 07-23-2007, 08:00 AM
  #31
KerryF's Avatar
After this thread I had to confirm that my pressures were in fact optimal for my settings/tires. So I used a pyrometer to check, this was the type that uses a metal probe, not a laser.
F/R
I'm running S-03s 205/225.
Camber is -1.6/-2.5
Toe is 0/ 1/4"
The Pyrometer tells me that the optimal pressure to have maximum grip at all four corners is 45/43. So if your car is set up like mine, use those pressures, then adjust from there if you want more understeer or more oversteer.
EDIT: If you have less camber than me, you need to add MORE pressure to the tires.
Old 07-24-2007, 09:10 AM
  #32
CosmosMpower's Avatar
34F 32R for me, using RE-01R's with stiff sidewalls, gets up to around 38/36 hot.
RyanDavies
11-13-2014 01:31 PM
jlozano180
11-12-2014 10:41 AM
rjones
04-25-2011 06:41 AM
ayelien
06-11-2004 10:11 AM
Clovis
24
09-24-2002 12:07 PM
Quick Reply: Tire Pressures for Solo 2 Autocross Event?
