Tire Pressures for Solo 2 Autocross Event?
If you don't have a pyrometer, chalk will do. I started at 32 PSI cold and worked from there based on pyrometer readings. Still running less than 40 PSI hot.
Originally Posted by GTI 20v,Jul 12 2007, 04:24 PM
Why do people insist on posting even when they have no idea what they are talking about?
yeah, chalk is the most common method I've seen used.
At my first AutoX I ran 40f and 34r, fearing the snap oversteer these cars are known for.
Next event I'll be around 42/38 or so, as the car's ass still slid around quite a bit.
Originally Posted by __redruM,Jul 12 2007, 05:23 PM
I posted because there was one other opinion and I was curions about why 40psi was good for autocross. I was certainly willing to admit in my post that I knew little about the subject of autocross. Thanks for both helping to clear things up and acting like a bitch both in the same post.
You didn't ask why 40 psi was good. In fact you didn't ask a single question at all. You were trying to answer questions...incorrectly.
In my book, the bitch is the one who pretends to know things he doesn't, not the one who calls that person out.
I NEVER pretended to KNOW what what the absolute right presure for autocross. I gave my GUESS and the REASONING behind it. All with the disclaimer that I have never experimented with tire presure at autocross. And I invited someone with more experience to correct where I was wrong.
This is what people do on forums. They discuss TOPICS. I wished to participate in the discussion. And so I did. If you want to decided who can and cannot post in topics, go start you own damn forum.
You're right. When someone asks a technical question, we should all just guess at an answer, whether we know anything about the topic or not. That will definitely improve the helpfulness of the forum!
You need to recognise the difference between someone asking for opinions, and someone asking for technical answers. Because it's a big one.
However with really tight turns, if you lower the pressures too much, you'll roll the tire over onto the sidewall or the car won't rotate, which is why its normally better to run slightly higher pressures. Plus, higher pressures let the tire heat up (ie get grippy) faster, which is very good when driving on courses that usually are less than a minute long.
40psi seems reasonable, AutoX runs are less than a min. You want to get tire temp up ASAP.
It all depend on race courses, track condition, car setup, and driver prefference. I like more psi in rear than front for RWD cars. The rear seems to rotate thru corner alot better and the front not choppy and understeer.
just my 2cents
