tire pressure's?
tire pressure's?
This will be my first time tracking the S and I have a set of Toyo RA1 255's on the rear 245's on the front I would like to know what tire pressure I should start out at the track is 1.23 miles lots of braking zones and flat as a board.
thanks for any help
thanks for any help
i dont have any experience with the RA1, but i would start with slightly under oem's recommendation. Last time i was at the track i filled them to 30 psi, then i marked the side to see how much the tire is flexing.
perhaps some pro should share about their experience
i've found 37f/34r hot pressures to work on my 235/255 r888 on stock ap2 wheels sufficient. tire has some sidewall roll, but it is not bad once you get used to it.
