Tire pressure on my RE-01R's?
Old 11-28-2009, 12:57 PM
lude9285's Avatar
Default Tire pressure on my RE-01R's?
Hey guys ive done some searching but haven't found much. I found an older post stating to start the tire pressures at F/37 R/32 on street tires.
I was wondering if you guys could give me an idea of what pressures to start at with my set up for an auto x event tomorrow.
Im running RE-01r's
18x8 225/40
18x9 265/35
Thanks!
Old 11-28-2009, 04:29 PM
CKit's Avatar
Are you running stock spring rates and shocks?
Old 11-28-2009, 04:32 PM
lude9285's Avatar
No apex n1 exv...dropped 1 inch
Old 11-28-2009, 04:41 PM
CKit's Avatar
If you're new to autocross, run "whatever" pressures it takes to keep from rolling over. See what your balance is like first. You're running more rear tire "width" than normal and you might get understeer.
I wouldn't worry about the actual tire pressures that much if you're new.
You could start square 35psi cold and work from there.
Old 11-30-2009, 11:52 AM
TubeDriver's Avatar
Try MUCH lower cold pressures with RE01Rs. ~26 rear and ~28 front. Cold.
Old 11-30-2009, 11:55 AM
SILAP1's Avatar
yea id say somewhere around 30 to start cold is a good idea the work from there .
Old 11-30-2009, 12:02 PM
bellwilliam's Avatar
[QUOTE=TubeDriver,Nov 30 2009, 12:52 PM] Try MUCH lower cold pressures with RE01Rs.
Old 11-30-2009, 12:22 PM
CKit's Avatar
And who knows what "cold" pressure is in his climate. In the late fall over here, 35psi cold winds up being ~37 psi "hot."
Old 11-30-2009, 02:13 PM
goldenfri's Avatar
I ran about 30 front 28 rear cold on mine, thats where I found the most grip, but I'm no expert.
Old 12-01-2009, 09:22 AM
AlexS2200's Avatar
Location: 13851 A Better Way #11D, Garden Grove, CA 92843
34 psi hot is the best IMO
Quick Reply: Tire pressure on my RE-01R's?
