Threshold Braking and Clutch Operation
When ABS engages the wheel has stopped turning, something the engine is fighting against.
Are you looking at the freakin' RPM gauge while threshold braking? Can you hear your engine exhaust on track at idle throttle and low rpm? You don't gain any feedback from having the clutch engaged.
Leaving the clutch engaged during the entire braking zone will allow the input shaft to slow with the drop in road speed. To get the input shaft up to the speed needed to match a proper downshift you will have to double-clutch as mentioned above or downshift through every gear.
I think you're confused about the input shaft.
???? No double-clutching required, nor downshifting through every gear. You will have to match input shaft speed to road speed whether you keep the clutch engaged or disengaged. In fact if you declutch as soon as you start braking, presumably you're just at idle until you need to shift, so a much greater rpm disparity to get to the appropriate rpm for the next gear down vs. leaving the clutch engaged.
With the clutch in and in neutral the input shaft is disconnected and spins on its own and slows due to friction. Engaging the clutch while in neutral (double-clutch) will match the input shaft to engine speed. Rowing down through the gears also engages the input shaft to keep it spinning. I don't do either, I allow the syncros to match the input shaft to the transmission during my one downshift (this happens with the clutch disengaged and the shifter is snicked into gear).
My engine is at idle at the end of the braking zone but a good heel-and-toe blip matches engine speed to transmission speed no problem.
What's your published source for keeping the clutch engaged?
I disagree with your opinion, The gain comes from not having to waste braking energy to overcome the drive of the engine.
My technique works. I turned a 121.7 lap at Summit Point Main with a stock engine/transmission/gearing and I've never had any clutch, transmission or differential problems.
View my video above and witness the fastest S2000 lap ever videotaped around Summit Main.
Leave the clutch engaged except briefly while shifting. This will always reliably put you in the appropriate gear at the end of the braking zone even if you're totally unfamiliar with the track/road, and will do a better job of ensuring you're always in total control of the car.
The only time you should be on the clutch and on the brakes (other than briefly while downshifting) is if you are in a spin.
ABS prevents the wheel from stopping. The only time the engine would "fight" against (act in opposition to) the brakes with the clutch engaged is if you brake all the way down below idle speed. Or step on the gas while braking.
Take a look at an ABS skidmark. Black lines broken up where the ABS releases brake pressure. Where there is skidmark the tires are not turning (watch some super slow motion of ABS braking). Your drivetrain is going from standstill in the skid--to rotating when ABS releases brake pressure.
TACHOMETER (do you call the speedometer the "mph gauge"?
Now you sound like a little girl.
I use a Sparco pedal on the accelerator pedal so I can roll the top of my foot to blip the throttle. Without the additional pedal I couldn't blip the throttle with my heel on the floor.
ABS can leave stitched black marks without the wheels being locked, and anyway the drivetrain being engaged isn't negatively affecting ABS function or braking (if anything it's HELPING). Would like to see superslomo of ABS, I wouldn't think a modern system would react so slowly that the wheel actually locks...
You are doing it wrong. Ask any of your fellow competitors and instructors what *they* are doing with their clutch in the braking zones. Extremely poor form to have the clutch pedal to the floor through the braking zone.
In a modern sedan based race car with ABS the rear tires will be in ABS if you're threshold braking the front tires due to the stock brake bias being designed for the street and street tires.
While instructing for Bill Scott Racing (BSR) we had a braking drill we'd have our tactical driving students perform to learn max braking in a turn. We'd turn ABS off and while in a moderate speed turn brake until the inside rear wheel locked up. Skidding the inside rear allowed more braking to the other three tires for a maximum performance stop. The key was to modulate between one locked tire and two. If the outside rear locked too you would loose directional control. It was a great way to teach brake modulation techniques. It's amazing how quickly a 65 year old female State Department employee can learn to threshold brake using this technique.
We also had a drill to threshold brake while driving at max speed in reverse (simulating reversing out of a terrorist attack). With normal front brake bias the front tires lock up much easier than you'd expect.
My point is I know braking and the S2000 brake system. I didn't pull my threshold braking technique out of my butt. Does your Z car even have ABS?
Regardless of ABS or no, having the clutch disengaged throughout the braking zone is a bad habit for reasons mentioned above.
Of course the 240Z doesn't have ABS (neither does the S at the moment, actually). Makes no difference, the proper technique is to keep the drivetrain engaged, with or without ABS.
The original poster said he couldn't find any reference to the clutch in the Barber Racing book. I don't recall ever reading about clutch technique for threshold braking either. I'll review my textbooks when I get home and see if I can find anything. Maybe you should do the same.
The factory brake bias on a production car has been very well developed for the last decade or so. However, these systems are designed without the "engine-brake" in mind. So, theoretically, if you were to leave the clutch engaged while in gear, you are adding to the brake torque done on the rear tires, making the complete system rear-biased. If your car can slow-down faster than the powertrain can reduce in speed, you are adding to the brake torque NEEDED to the rear tires, making the complete system front-biased.
What robrob outlines is a great way for novice to advanced drives focus on their braking ALONE and develop a good sense of modulation. Even at the competition level, I have seen drivers use this technique. Being in the right gear ALL THE TIME may not retrieve lost seconds, but being able to brake at 100% efficiency makes up seconds in racing.
But then again, in wheel-to-wheel racing, you never know when you might need to throttle out of a sticky situation.
