Thoughts from R&C crew on this brake swap
Rather than cutting your rotors to be thinner, you can mill 2.5mm off each brake pad. There may even be enough room with the caliper piston pushed all the way in to get away with taking 2mm or less off each pad. You will go thru pads faster, but can still retain the stock rotor thickness.
epnfrn
12-19-2003 08:36 AM
