T1r BSK replacement parts
i have a used T1R Rear bump steer kit..and after reading about the possibility of the pin sheering like in momofoolio's case, i'm a bit concerned. Does anyone know where i can buy new tapered pins (part that attaches to knuckle) ? Finding the spherical male ends is not a problem, but i haven't found the pins. if someone could point me in the right direction, i'd appreciate it. thanks.
here's momofoolio's thread.. https://www.s2ki.com/forums/index.ph...ic=739016&st=0
thanks, i figured i have the damn bsk and instead of buying new ones i'll just replace what could fail. I saw either Aurora or NHBB. But i couldn't find the part that goes into the knuckle. the part that failed in your situation..if you have any ideas. let me know. thanks.
id just go with megan (abt $165 a set) and replace with new set every year!
couple other ap1s have been running this setup trouble free =)
but hey if u can find replacement bearings for 20 bucks why not!
but the last time i check they were 80 bucks for all four =(
Where did you buy your megan bsk?
Jim
