Sway Bar Installation
Old 01-06-2007, 10:22 PM
i2ichal2d's Avatar
Default Sway Bar Installation
hey guys, i have searched and dint get too much info, and have some questions
i heard that the front wheels have to be removed? (neve rhad to do this with other cars ive worked on).
also when i looked at comptechs instructions for sway bar install, it said for the rear i had to remove the exhaust?!?!? b/c thats gonna be a bitch!!
so please chime in with some info! thanks!
Old 01-07-2007, 05:49 AM
Administrator
cthree's Avatar
The sway bars are held on with 4 bolts and 2 end-links. It's very simple and you don't have to remove the wheels or the exhaust of you don't want to.
Old 01-07-2007, 06:11 AM
CRDMS1's Avatar
I've never removed the rear sway, but removing the stock exhaust is only a 10-15 minute job once the car is up on stands.
- 5 hangers, 3 flange bolts, plus rear brace (4 + 1 bolts IIRC)
You can do it yourself if you have some muscles and don't mind getting dirty
Old 01-07-2007, 08:08 AM
i2ichal2d's Avatar
thanks!
Old 01-07-2007, 08:55 AM
Gloffer's Avatar
I don't know how you'd get to the end links without removing the wheels. Even if you could, removing the front wheels makes everything so much easier. Here's the Saner bar install instructions that should also work with minor changes for most of the other bars out there.
http://forums.s2ki.com/forums/index.php?showtopic=174999
I think the Comptech website has detailed instructions for a Comptech bar install.
Old 01-09-2007, 08:25 AM
Mad_Paradox's Avatar
i installed cusco sway bars on my car before no need to remove the wheels everything can be done with the car jacked up on jackstands. The rear you might want to remove the exhaust so it isn't such a pita hit me up if you need help richard
Old 01-09-2007, 11:58 AM
gfacter's Avatar
You really should load the suspension before tightening the bolts.
Old 01-15-2007, 01:30 PM
riokong's Avatar
I removed wheels and the the front plastic under cover to install front sway and unhooked the exhaust from the hangers....I don't see any other way around it.
Old 01-27-2007, 11:38 PM
S2Koupe's Avatar
any tips on removing the rear exhaust to install a rear swaybar?
really, i tried to put some muscle into it. it didnt seem to want to budge and my patience ran out.
whats effective? grease? pry bars? unbolt the front flange first?
Old 01-31-2007, 08:57 PM
S2WOOOW's Avatar
Take the rear wheels off and work the hangers from the wheel wells. Spray some lub on the rubber hangers.
Quick Reply: Sway Bar Installation
